Radeon HD 2600 XT vs. GeForce 8600 GT
Written by Tim Smalley
August 14, 2007 | 12:01
Tags: #256mb #2600 #8600 #g84 #gddr3 #gddr4 #geforce #gt #hd #radeon #rv630 #xt
Companies: #amd #asus #ati #nvidia #sapphire
Power Consumption:
On top of our graphics performance testing, we have also measured the power consumption of these graphics cards at both idle and load. For this we used our standard test system configuration listed earlier on in the review.
For our idle testing, we left the systems idling on the desktop for ten minutes, recording the average draw at the wall socket. For load testing, we used our benchmark routine from The Elder Scrolls IV: Oblivion and measured the peak power consumption in this section of the title. We tested the cards in a number of other scenarios and this proved to be the most intensive in all cases, so you can consider this to be a worst-case scenario.
Bear in mind that we have disabled all CPU-related power management options in the motherboard's BIOS so that we can highlight exactly how well the GPU's power management features are working (or not).
Idle Power Consumption
Sitting on Windows Vista Desktop (Aeroglass Enabled)
  • Asus EN8600GT 256MB
  • Nvidia GeForce 7600 GT 256MB
  • Sapphire Radeon HD 2600 XT 256MB GDDR4
  • Nvidia GeForce 7900 GS 256MB
  • ATI Radeon X1650 XT 256MB
  • Nvidia GeForce 8600 GTS 256MB
  • ATI Radeon X1950 Pro 256MB
  • ATI Radeon X1950 XT 256MB
  • 90
  • 95
  • 98
  • 98
  • 101
  • 101
  • 107
  • 110
50
75
100
125
System Power Consumption (W) - lower is better
Loaded Power Consumption
The Elder Scrolls IV: Oblivion 1280x1024 0xAA 16xAF
  • 138
  • 139
  • 142
  • 154
  • 158
  • 162
  • 166
  • 217
100
150
200
Not only does the Asus EN8600GT 256MB deliver a better gaming experience (on average) than the Sapphire Radeon HD 2600 XT 256MB GDDR4, it also uses less power in the process too. Idle power consumption is typically a strength of AMD's ATI Radeon graphics cards in the past, but this time we found the Asus EN8600GT 256MB to use 8W less power than the HD 2600 XT GDDR4 when idling.
null
